SR20DET - Definately NOT Impressed
I swear after going through this thread countless times, I'm STILL undecided as to what route I'm going to take again.
dammnit.
But at the same time, all the info or opinions are really building up a pro/con list for all 3 motors.
So keep going
dammnit.
So keep going
Originally posted by PROJECTRB240SX
just use the r32/r33 crossmember and mounts and it bolts right into car. the s13/s14 shaft fits perfect and the only mdification you'll have to do is the hood skeleton needs to be cut.
With engine mounts its even better. Greddy doesn't make one for the rb20.
It is a perfect fit..... and if you want to get ******** about it, niether is the sr or ca because you have to cut and splice wires.
As if the RB wiring harness is a straight drop in as well? Or how about the gauge cluster?
******** or not.
Go on www.nissaninfiniticlub.net and search for the wiring guide to the rb20/25 into s13. there is a few of them.
I don't know about you but a air saw, cutting wheel, die grinder works faster than stripping, crimping, soldering, heat shrinking, sheathing, and taping.
I never said the rb harness was bolt in I said if you wanted to get into semantics none of these swaps are a perfect fit.
hehe
