car wont start
Old May 20, 2006 | 06:43 PM
car wont start
ok so my car is a 1993 240sx with a ka24de engine. i start my car and take i down to the car wash to wash it. after im done i get in my car to go back home and it wont start. it wont even turn over no noise nothing. its not the battery because me and my dad had autozone check it out and its still good. we replaced the ignition fuse in the fuse box and it still doesnt start. any of you got any ideas? i dont know if this has anything to do with it but when i was washing it i wasnt paying attention to where i was sparaying for a couple seconds and some water got into my exhaust. could i of just flooded it out? any replys with be helpful.
Old May 20, 2006 | 09:00 PM
g3bio's Avatar
No it would not make a difference with spraying water in the exaust i have done it, its not good but it should still work. Try the starter is an idea, Alternator as well because you might have had the alternator go and still some juice in the battery before she died fully at the car wash. Good Luck figuring it out
Old May 21, 2006 | 12:30 PM
slimbung's Avatar
I would definatly take a serious look into the altenator. I have had mine go out on me and My car would also act like that too. Also the Starter moter is definatly something else worth looking at if it is not the altenator.
Old May 21, 2006 | 01:48 PM
do any of you know what the switch under the drivers side dash is for. i started messing with and now my car starts up fine. im still gonna take it to the shop to have it checked out though.
Old May 21, 2006 | 06:08 PM
g3bio's Avatar
wtf? i never seen a switch there? if i seen a switch im sure i would have played with it. no clue dude.
Old May 21, 2006 | 06:31 PM
i think i found out the problem.. that switch under the dash i think is the kill switch. i was messing with it before and i must of set it to off and it would start. mabey they only came on the 93's cuz i have an alarm system on my car and i guess the kill switch was part of the system. i hope thats all that was wrong with it though.
Old May 21, 2006 | 07:41 PM
g3bio's Avatar
i know i have a switch i played with once and it wouldnt turn on my alarm maybe its similar do you have an anti-theft immobilizer simmilar problem i thought of but the switch is located elsewhere. haha
Old May 22, 2006 | 07:02 PM
my car in screwed up again now. im pretty sure its the alarm system. my kill switch is screwing up so the only way to start it is to push start it and every time you open the doors or turn the key my panic lights go on. i think my horn is broken because when the alarm sets off theres no sound it just my panic lights. any one ever had this happen to there car or have tips for fixing it?
Old May 22, 2006 | 08:44 PM
slimbung's Avatar
If at all possible could you just disconnet the power to your alarm system and see if that could work.
Old May 24, 2006 | 10:37 AM
ok, i found the problem. even tho my alarm system is screwed up it wasnt that that was causing the not to start. i cant beleive i never checked this in the first place but it was the buttion thats under the clutch. the little rubber piece that was pushing it in had broken off so my clutch wasnt pressing the button. everything works now.
shigitySxSe
Jun 8, 2004 02:39 PM
masplinter9
May 13, 2004 11:26 PM
Project Cheap13
Apr 7, 2004 05:57 AM
TheStartingLine
Mar 26, 2004 07:34 PM
BeDrift
Jan 23, 2004 04:45 AM
