Check engine after intake install
Old Oct 20, 2005 | 03:01 PM
Badazz_240's Avatar
Ok..... i started installing my intake and right near the end when you are supposed to cut the hose ( aem instruction book ), i accidently cut it too short. So... I made a ghetto'd out hose using 2 different sizes ( one stuffed into another ), and it worked fine no engine light. Then i went to schucks to get a new hose, and when i was putting it on i had to remove the two plugs above the intake. I forgot to put them back on, and drove for about a block and was like... oh dam i forgot to plug those back in. So i plugged them back in and the engine light was still on. I got out my trusty ghetto'd hose and put it back on and the light was still there. so after all this i put back on the second schucks hose, and the plugs are in, but there is still an engine light coming on.
Has anyone had this problem with the sensors? ( they are to the left of the valve cover right above where the intake goes into the manifold right next to eachother)
Any help is appreciated
P.S. .... I already tried to do the whole computer reset thing, and the light is still on. ( unhook the battery )
Old Oct 20, 2005 | 05:22 PM
95s14zenki's Avatar
your ecu just threw codes when u drove with the hoses off, use http://www.ka24development.com/ecu_codes.html
those guides to reset your ecu..should get rid of the check engine light.
Old Oct 21, 2005 | 09:17 AM
Badazz_240's Avatar
thanks.... ill try it today after school...... by the way... how do you get to the ecu??..... i have no idea how to get it out
Old Oct 21, 2005 | 09:25 PM
lrb_2000's Avatar
passenger side kick panel.. remove the bottom door trim, then the panel..
cmhadley
Jan 22, 2006 10:52 AM
TheStartingLine
Jun 19, 2004 09:28 AM
SilviaJai
Sep 23, 2003 07:36 AM
