Firing order
Old Jan 20, 2005 | 06:12 PM
jackyliem's Avatar
Firing order
hey guys I just bought a set of NGK spark plug wire but when I change them I found that I might have the wrong firing order for all the time. I know the firing order should be 1-3-4-2 and I know that the cyclinder order are from the front (radiator for 1) to back (transmission for 4). however I have no idea which plug on the distributor represent which fire order. Although there are number labeled on the wire, I found that the # 3 wire are not long enough to reach the third cyclinder. I am so confused........ any body please help.
BTW. Would I be able to feel the differce for wrong firing order? cuz I am pretty sure I got #1 and #4 right. so the only problem is between #2 and #3
can anyone also post the picture of which cyclinder is which? thx
Old Jan 20, 2005 | 10:36 PM
R34 Racer's Avatar
If your firing order was wrong you'd know it. The car probably wouldnt start, would run on two cylinders, making it feel like driving a car with a lawnmower engine. Also, the exhaust would sound very pulsey, like a WRX at low revs.
Old Jan 20, 2005 | 10:41 PM
LTSCUDRFT's Avatar
For more info:
www.**********/faq/articles/timing101.htm
Old Jan 20, 2005 | 10:47 PM
jackyliem's Avatar
mine is a KA24E would the distributor and firing order be different?
Old Jan 20, 2005 | 11:06 PM
jackyliem's Avatar
is the cyclinder 1 on that picture mean the cyclinder closest to the radiator like what I meant?
Old Jan 20, 2005 | 11:41 PM
LTSCUDRFT's Avatar
OKay........ take out the 1st spark plug rotate the crank until you hear a hissing sound (that is you #1 piston coming to TDC)
when the hissing stops, take off the dist. cap and the roter will be pointing to the #1 sparker (or very close to it), from that your firing order goes clockwise.. or just like the pic, it's not too hard to figure out.
Old Jan 21, 2005 | 02:26 AM
wikd240's Avatar
on his ka24e and all the other caps the number 1 position is marked on the cap... start at one and go clockwise... on my ka24e the #1 position was close to the bottem of the distributop closest to the ac compressor... dont have pics cus isold the motor on wednesday...
Old Jan 21, 2005 | 09:05 AM
1-2-3-4 from radiator (front) to tranny (rear)... just follow the picture posted with the distrib and wire it up 1-2-3-4.
Old Jan 21, 2005 | 10:32 AM
jackyliem's Avatar
oh well I finally found out my firing order. cuz having wrong fire order is significant.
mind is (ridiator)-------->(tranny)
4 3
2 1
Old Jan 21, 2005 | 10:44 AM
4 3
2 1
um... my #1 wire is to the cyl closest to the rad... all the way to #4 at the back.
Something's wrong there.
Old Jan 21, 2005 | 10:56 AM
jackyliem's Avatar
those number represent the number on the distributor cap. cyclinder #1 is still closest to the radiator.
btw I found the number on the distributor cap so I am positive that I got it right
Project Cheap13's Avatar
It all depends on how someone put in the distributor. When 1 is on TDC, they probably just droppped in the dist & lined up the #1 plug wire with the rotor. While its ok to do that, it is wrong.
The PROPER firing order is as follows.
<front of car, in a counter-clockwise rotation. The firing order is 1,3,4,2
31
42
TOP..
1 being nearest the firewall. 3 near the radiator
BOTTOM
4 near radiator & 2 firewall
This is the PROPER way it should be done.
On that picture, just move the cap in a CLOCKWISE position by one plug wire cap & that would be correct( THIS IS FOR THE KA24E RWD). The way the one in the pic is set up is for a FWD car, like the stanza, ect...
Shemyazaz
Aug 10, 2007 07:24 AM
boney
May 7, 2006 10:22 AM
drifterswanted
Dec 15, 2003 10:20 PM
war
Nov 14, 2003 08:24 AM
silS13
Oct 22, 2003 04:37 PM
