Oil above the spark plugs?
Old Dec 11, 2003 | 06:17 PM
drifterswanted's Avatar
What would cause oil above and on the spark plugs,
I had my car towd to a last week...
thx,
J
p.s. how do i get it out...
Old Dec 12, 2003 | 11:05 PM
devnull's Avatar
I don't know the proper way to remove that oil, but I can tell you that it's because the one of the valve cover seals has gone bad. Easily replaceable, but I don't know what to clean out the spark plug holes with.
Old Dec 13, 2003 | 11:17 AM
soak up as much as you can with paper towels, etc with the spark plug STILL installed, the rest spray off with enging cleaner once the valve cover is off. Yes, I said "off" because you're going to replace the seals anyways. Then I guess the last thing left to do is replace the spark plug, wich probably is doused with oil and engine cleaner by now
s14 gtst
Jul 23, 2005 05:36 AM
Craig577
May 23, 2004 08:48 AM
U_NeeKz
Apr 16, 2004 06:26 AM
doua
Mar 15, 2004 04:40 PM
sleighty
Feb 28, 2004 09:28 PM
