KA-T Build?
Old Jul 28, 2009 | 12:30 PM
Handsome Rob's Avatar
KA-T Build?
I actually only have one question. I am getting a stock turbo off of an Evo VIII and I was wondering what would be the best header to use this turbo on a KA24e? I just want something that will be somewhat reliable.
Old Jul 28, 2009 | 12:44 PM
USMCDrifter's Avatar
You mean manifold? I assume you'll require a turbo manifold that fits the 16g pattern (that's the turbo I believe the 4G63 uses). As far as "reliability", well, as long as it's properly milled at the fittings and flanges, piping is piping and should hold up to . . .whatever it is that people do with KA-T setups.
-Dave
Old Jul 28, 2009 | 02:54 PM
there are many variation of manifolds for the KA24de however not so many for the KA24e... so you will either have to make it and or just get one premade and swap the flange. check out jgstools.com
Old Jul 29, 2009 | 09:02 AM
Isn't it twin scroll? For your purposes your best option is probably a fully custom log manifold
Old Jul 29, 2009 | 09:26 AM
So the turbo is a TD05HR-16G6-9.8T what size flange is equivalent to this?
Old Jul 29, 2009 | 10:16 AM
this is what you're dealing with...
Divided housing (twin scroll) Mitsubishi flange. You are going to have to make your own divorced manifold or modify a Mitsubishi one to use on your sohc. The latter is probably your best option if you really want to use that turbocharger.
Old Jul 29, 2009 | 11:22 AM
Awesome FML!!!!!!
Old Jul 29, 2009 | 12:20 PM
I don't see that being too much of an issue, so you can't use that turbo easily, so what? Just sell the turbo to someone else, buy a T3/T4, manifold and downpipe and rock that.
Sounds like the easiest plan and requires very little fabrication.
ya go simpler.. those flanges are proprietary has hell.
Old Jul 29, 2009 | 12:36 PM
Thanks for all the help, I will look into it.
Old Jul 29, 2009 | 12:47 PM
By look into it he means, totally disregard the project and post the car on Craigslist, LOL!
j/k
lrb_2000
Nov 23, 2004 10:27 AM
MoneyWanted
Oct 29, 2003 07:45 PM
DAVID ROGERS
Jul 17, 2003 09:24 PM
mmbd
Jun 25, 2003 03:56 PM
spitz7985
Jan 21, 2003 08:26 PM
