1993 240SX Power Loss
Old Nov 23, 2006 | 01:06 PM
positron's Avatar
When I'm driving at night with the lights on, why drive at night with them off, the heat on and the rear defroster going and I shift into neutral and start to come to a stop the car feels like it's going to die sometimes. The head and dash lights flicker, you can hear the heater kick back a little and the rpms drop to almost zero until I step on the clutch again. WTF!!!
Old Nov 23, 2006 | 03:34 PM
re037's Avatar
recharge your battery and get your alternator checked out.
Old Nov 23, 2006 | 09:35 PM
LITTLEDEVIL S13's Avatar
yeah thats exactly where i would check first battery & alternator... but do not over look the grounding system... check or grounds for corosion (green stuff) ... and if u want u could upgrade to a ground wire kit...
good luck
Erik
Old Nov 23, 2006 | 09:39 PM
positron's Avatar
I've got a ground wire kit with the correct mounting points and a voltage stabilizer. Stupid question time...but the parts store can check the alternator can't they? I'll check for corrosion in the morning. Thanks!
Old Nov 23, 2006 | 09:54 PM
well then okay do you install all of that yourself wires and regualtor? if so alway double check your work... and that wasn't a stupid question usually auto zone and advance auto have machines to chack alternators..... but i'll give u a heads up sometimes the people working there don't know what there doing and they will hook it up wrong there for showing u that u have a bad alt. but in reality its still good.... but if the price is right i would replace cause these cars aren't getting an newer.. and usually they came with a good warranty.... hope that helps u out
-Erik
Old Nov 23, 2006 | 10:04 PM
positron's Avatar
Yeah, I installed the grounding kit and stabilizer myself to spec. I will double check them when I check for corrosion. Thanks for the heads up on the "parts gurus". The car is 13 years old and it could be time for a new alternator but I'm so close to a swap I can taste it.
gotboost
Dec 5, 2007 11:10 PM
Drift~O-RX7
Aug 6, 2005 11:05 AM
re037
May 6, 2005 09:44 PM
240sxFan
Mar 4, 2004 05:19 PM
fastback
Jun 9, 2003 10:19 AM
