248 248 cam swap question
Old Mar 10, 2009 | 08:04 PM
sav180's Avatar
do anyone have a pic on how the 248 cam swap is suppose to look like so i can make sure im golden??i use the 4 teeth method and was wondering if there is a better option??..the idle is a lil ruff for me,i gotta hit the gas a couple of times to get her started...
Old Mar 10, 2009 | 08:05 PM
sav180's Avatar
000 yea ...would you guys recomend using a fpr with walboro pumps or a afc should be fine??using stock injectors for now with 89 pistons
Old Mar 10, 2009 | 08:07 PM
sav180's Avatar
my b 90 pistons the flat tops
Old Mar 10, 2009 | 09:39 PM
240smoke's Avatar
What motor do you have?? And it would help if you would write in english, not gibberish. HAHA. Cant understand what your trying to ask.
Old Mar 11, 2009 | 07:18 AM
sav180's Avatar
lol my b..i was kinda of fallin asleep when i started this thread..i have the kade..
Old Mar 11, 2009 | 01:14 PM
hatrick6's Avatar
the 4 tooth method is the one i had always read about, were you set to TDC when you did the install? and does changing the idle speed do anything for the rough idle?
also, don't suppose you got before and after dyno numbers for this?
Old Mar 13, 2009 | 07:18 AM
sav180's Avatar
i set the tdc to stock location and did the 4 tooth method..the 1st set of lobes has to face away from each other right???
Old Mar 13, 2009 | 07:20 AM
sav180's Avatar
do anyone has a pic of the cams so i can see if i did it right..do u do it by 4 chain links or 4 holes for the teeth
Old Mar 15, 2009 | 12:50 PM
BigVinnie's Avatar
Obviously, it is a KA engine that he is talking aboujt by the lift/duration cam that he is using 248/248. Anymore HAHA's and post whoring out of you; you and I will start to have some serious problems. Your comments on this forum are the only gibberish I see.
Old Mar 16, 2009 | 06:57 AM
Preston's Avatar
The four tooth method is great for bottom end torque, but you will never have a smooth idle. The engine doesn't create a steady vacuum to keep itself running right. i never adjusted the idle speed when I had mine, but I doubt it will help. Running the three tooth method gives a perfect idle with a better top end boost.
Old Mar 16, 2009 | 10:32 AM
sav180's Avatar
yea...u wouldnt have a pic of what the 3 tooth looks like??the idle is a lil ruff
Old Mar 23, 2009 | 08:22 AM
sav180's Avatar
has any one tried the 240x240 cam swap??how do u set up the 240 cam on the exhaust side?vinny i know u know
Old Apr 9, 2009 | 08:56 AM
RMS13FU's Avatar
The intake cam on the exhaust side would be rotated the same amount of teeth, in the opposite direction
Old Apr 11, 2009 | 10:16 PM
sav180's Avatar
oo ight i tried the 240x2 and 248x2..dont really care for how the idle feels.its totally crappy..i jus went back to stock till i get some bc's
sav180
Aug 22, 2009 07:32 AM
1991se240sx
Aug 16, 2009 09:53 AM
alkemyst
Jul 21, 2008 07:18 PM
All Mighty KA-T
Jun 7, 2006 03:19 PM
jfrederi01
Aug 8, 2005 03:18 AM
