clutch concern
Old Dec 4, 2006 | 04:52 PM
shigitySxSe's Avatar
Angry clutch concern
Ive searched and read up on some similar problems ppl have wrote on the forums but still want some opinions... I drive a 92 coupe, dohc 5-speed, and I just noticed tonight that theres a strange noise coming from the front of the car as i depress the clutch and go to put my car into gear. not a high pitch whining or popping noise, but a noise similar to...the power antenna going up or down....that "type" of sound. And its not exactly hard to put it in gear, but i notice a noise that i didnt notice before today. It doesnt happen with the car in neutral, only when i press the clutch in, and try to put it into any gear. It just started snowing today but i doubt that has anything to do with it? Is it TO bearing issue? Im gonna go out and drive it up the road to see if i can diagnose it any further tonight, but please throw out some opinions...other than search. Thanks alot
one other thing i was having clutch issues before but it was the slave cylinder. i replaced that and the master, and everything has been fine since...
If this is a TO bearing problem, how bad is this gonna be?
Old Dec 5, 2006 | 07:08 AM
prolly the throw out bearing, nothing to major, just get a new clutch and replace it
Old Dec 6, 2006 | 12:11 PM
Chief_Suicide's Avatar
clutch
Does this happen everytime you push the clutch in, or just the first time after you start it? Or maybe just the first time after it sits for a little?
My five speed makes a similar noise, but only after it has sat for several hours.
Old Dec 6, 2006 | 06:20 PM
Mika's Avatar
if youre pressing the clutch in and its making the noise then this is the pilot bearing. if its making the sound w/o the clutch being pressed its the t/o bearing. (pretty sure)
this sound used to happen on my car too, replaced the pilot bearing with the new clutch and use dthe same t/o bearing b/c it was still spinning great. no more sound
EJ253
Dec 19, 2006 08:38 PM
re037
Sep 1, 2004 09:03 PM
DaPCWiz
Aug 23, 2004 06:35 AM
nerd22
Aug 20, 2004 12:32 AM
leiferik1
May 2, 2003 03:46 PM
