distributor, TDC, Help!!!!
Old May 23, 2006 | 01:54 PM
x3240racer's Avatar
Question distributor, TDC, Help!!!!
Ok guys. The other day I put a tensioner in my ka24de. I guess the distributor didnt get put back in the right way. My manual doesnt explain the process of re timing it. So im asking you. With the distributor out. Do i bring it to TDC. then what way do i put the distributor in. SHould the rotor be pointing a certainway. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!1
Old May 24, 2006 | 07:47 AM
thuan's Avatar
turn your crank till its tdc then spin you distrib. till its align with that big dot on the shaft and stick it in
josh240caseysx
Mar 23, 2007 09:29 PM
98cwitr
Apr 11, 2005 08:27 AM
epoxy
Feb 21, 2005 09:54 PM
DriftS14
May 16, 2004 08:39 AM
