Help me out here, just a little bit.
Old May 7, 2009 | 12:32 PM
Nickmerrone's Avatar
I have an S13. Blown KA24DE. Getting an S14 KA24DE..
What all do I have to swap over to make it work in my S13?
give me a descriptive list, PLEASE.
Old May 8, 2009 | 02:07 AM
trust me... its all you need because i used the same info back in 05
https://www.s-chassis.com/forums/how-tos-installations-48/ka24e-ka24de-swap-40949/
Old May 10, 2009 | 07:05 PM
thats for a kae not kade.
Old May 10, 2009 | 09:19 PM
uhm................. it all applies... and that is for a kae to ka24de
Old May 11, 2009 | 10:27 AM
YangpaNemsay's Avatar
AFAIK, the only differences between the S13 KA and S14 KA is
- OBDI vs OBDII (more emissions)
- ECU (fuel maps are different)
- Internals (S13 240/248 cams ~ S14 232/232 cams
- SCV butterflies in S13 and not in S14
- No AIV PAIRS from 1994 and later
I'm sure there are other little things that differ between the two.
I don't know how different the body harness is from 13 to 14, but as long as you can get the ignition/starter/fuel pump wires spliced or plugged correctly, you should be good to go.
Old May 11, 2009 | 12:16 PM
^^ +1
nick you basically need everything from a obd1 s13 that is already listed in the list of "things needed" it doesn't get any easier bro.. im sorry.
Old May 11, 2009 | 12:44 PM
So im going to need an S14 ECU?
Old May 11, 2009 | 02:50 PM
1991-1993 parts:
-Wiring harness (tach if you want the tach to work)
-ECU
-Power steering pump AND lines.
-A/C compressor and lines. (unless you can make a bracket for your original one.
-Distributor and coil
-Intake manifold
-Throttle cable/cruise cable(if you like things all nice and neat)
-Extension Piece that goes from butterfly to intake piping(again, if you like it nice and neat)
-MAF
Old May 11, 2009 | 04:21 PM
1991-1993 parts:
-ECU
-Intake manifold
-MAF
I cant use my current wiring harness or tach?
Old May 12, 2009 | 01:41 AM
yes if its obd1 which yours is.... all you are doing is swapping all the s14 stuff off, however, if its a manifold without the secondary swirl valves... keep it and just swap the electronics and TB from your obd1 manifold to it. Nice little free mod.
240-kid
Dec 26, 2007 12:59 PM
epp_b
Jul 8, 2007 05:18 PM
shayan
Jun 9, 2006 12:34 PM
Ricky240sx
Sep 22, 2003 08:45 PM
albert
Feb 24, 2003 09:06 AM
