Jerking Problem
Old Feb 4, 2005 | 10:31 PM
dark_controller's Avatar
Jerking Problem
Once in a while my car will start to jerk violently, and when i rev it in neutral, the rpms kinda jump. anyway, i need some help, what do you guys think it could be?
Old Feb 5, 2005 | 05:04 AM
codyj86's Avatar
dirty injectors?
Old Feb 5, 2005 | 02:53 PM
could it be anything else
Old Feb 5, 2005 | 05:52 PM
reelten's Avatar
im sure internet **** is 100% of your jerking problem.
Old Feb 5, 2005 | 06:02 PM
hmmm...could be.
Anyway, i replaced the fuel filter and the gas that came out of the filter was quite black. I also dumped a can of injector cleaner in the tank. Hopefully that fixes it.
Old Feb 6, 2005 | 12:14 AM
well....things havent gotten much better...It started acting up after i filled up my tank. Any thoughts? Oh, also my check engine light came on...
Old Feb 6, 2005 | 01:58 AM
thecalikid's Avatar
ummm... what code did it throw?
Old Feb 6, 2005 | 10:07 AM
Dont know, i havent had it checked and i dont have the tool. Would a '95 240 use OBD II?
Old Feb 9, 2005 | 09:06 PM
BigVinnie's Avatar
You can get OBD2 decoders at JCwhittney. I payed 39.00 for mine.
If you are getting a jerking problem you may want to check your timing chain and timing chain tensioner, the components could be locking up, or the chains could be stretched.
Old Feb 9, 2005 | 09:10 PM
I dont think it is that,cause it doesnt do it all the time. And it only seemed to do it when it was warm out (23 degrees and above), i think there might be some water in my gas tank.
Old Feb 10, 2005 | 02:00 PM
drifterswanted's Avatar
I sorta had the same problem ...I tracked it down to my injectors were not getting a good ground....
my 2 cents....
thx
j
Old Feb 10, 2005 | 03:20 PM
djradam's Avatar
i don't think 95 is obd2. i hear 96 is, but 95 is 1
ill have to check that.
vortxxe
Apr 29, 2006 05:22 AM
uvamosk
Aug 12, 2005 07:31 PM
slowurroll
Jan 11, 2005 05:30 PM
kackarot
Feb 11, 2002 07:31 PM
240sxer
Feb 11, 2002 02:55 PM
