no start
Old Aug 10, 2006 | 08:09 AM
GEM's Avatar
GEM
Question no start
New member, so may make dumb comments or actions.
I drive a 93 SE with 71,000 miles. It's a great car, needing only new plugs, a set of front pads and a starting motor in its life. However, yesterday when it started it stumbled at very low revs for a few seconds, then quit and would not restart.
I disconnected the battery until today, hoping for a reset, but it still won't start. (Yes, I reconnected the battery.) It cranks willingly.
Any thoughts will be appreciated.
Glen
Old Aug 10, 2006 | 11:57 AM
re037's Avatar
you replaced the plugs right?
Old Aug 10, 2006 | 06:30 PM
GEM's Avatar
GEM
Yeah, that was a couple of years ago. The car has been running well & passed it's emissions test a month ago.
Old Aug 10, 2006 | 06:50 PM
re037's Avatar
well if your diagnosing from scrap, start with basics. make sure its getting fuel (injectors, fuel pump, fuel pressure) and spark (distributor, wires, ignition coil, ground).
Old Aug 11, 2006 | 06:30 AM
GEM's Avatar
GEM
I'll do that over the weekend & get back soon.
GM
Old Aug 11, 2006 | 06:51 AM
GEM's Avatar
GEM
I tried the SEARCH route, as suggested in the stickies, but got the message
Error: Host Not Accessible
The web host www.club240.com is not accessible.
every time.
GEM
Old Aug 11, 2006 | 05:55 PM
re037's Avatar
try ********.com they have a pretty good troubleshooting sub forum to help out
Old Aug 12, 2006 | 10:25 AM
GEM's Avatar
GEM
Thanks, re037. The car started toady and runs normally. Now I just have to find out why!
GEM
Old Aug 12, 2006 | 11:26 AM
re037's Avatar
hmm. weird, haha. i suspect electrical gremlins. gl figuring it out
Old Aug 13, 2006 | 06:38 AM
GEM's Avatar
GEM
I hear you! Thanks much for your interest.
Old Aug 19, 2006 | 12:48 AM
dkdeleon's Avatar
Check you Throttle position sensor connector. Have you washed or sprayed the engine bay lately? If so check for water in your spark plug holes, just disconnect one wire at a time and look for moisture around the spark plugs.
Old Aug 19, 2006 | 05:53 AM
GEM's Avatar
GEM
I have never washed the engine bay and the car is always parked inside. However, the TPS connector is a good suggestion, as it seems to idle too slow when it first starts, then comes up to correct idle speed.
The Oxy sensor has never been changed and the car was right at allowable limits for its emmisions test in June. Should that sensor be changed from time-to-time?
KAMAKAZI 13
Oct 24, 2006 05:08 AM
Slidin240
Dec 7, 2004 02:57 AM
kackarot
Sep 25, 2002 01:58 PM
cbarrios28
Feb 10, 2002 11:46 AM
nokuntrol
Feb 7, 2002 06:20 PM
