Overheating
Old Aug 20, 2004 | 12:37 PM
Lisas240's Avatar
Overheating
Car overheats after extended hwy driving. Replaced fan & fan clutch. Still overheating! Water pump replaced last Oct, car has 115,000 mi, radiator never flushed, has original thermostat. Also, small fan (A/C fan?) next to the radiator doesn't come on while the car is running or when I turn on A/C, should it? Wasn't using A/C on the hwy because it started to overheat even at a reasonable speed (75 mph) with A/C on.
Old Aug 20, 2004 | 12:51 PM
Temporary's Avatar
The smaller fan (A/C) should come on when you use the A/C. Also with my car, if i leave it idle long enough (about 10 mins) the smaller fan will come on by itself.
Old Aug 20, 2004 | 01:18 PM
Lisas240's Avatar
Thanks, that's what I thought. If the A/C fan isn't working that's probably why it starts to overheat when I run the A/C, except it only happens after extended highway driving. I don't have any problems around town at slower speeds. The temp stays normal even on hot days with the A/C running in stop & go traffic.
Old Aug 20, 2004 | 01:51 PM
Change the thermostat, flush the radiator and replace the a/c fan.
Moved to N/A!
Old Aug 20, 2004 | 06:53 PM
drnovascotia's Avatar
You answered it yourself!
Flush the system twice! Get a new t-stat, probably isn't opening like it should
get a new rediator cap.
Find out why the fan isn't coming on, it should.
Dr.
Old Aug 20, 2004 | 07:19 PM
djradam's Avatar
don't drive, then it won't overheat!
Old Aug 20, 2004 | 07:33 PM
**Totally off topic**
Doc, where you been!?
Old Aug 21, 2004 | 08:26 AM
Lisas240's Avatar
Don't drive? You might as well say don't breathe!
Old Aug 21, 2004 | 08:52 AM
I like that attitude
Old Aug 30, 2004 | 02:05 PM
Lisas240's Avatar
Took my car back to the shop that put in the new fan & fan clutch and guess what? The fan clutch they got from NAPA was bad! The shop manager ordered a new one (from Nissan this time) and will install it tomorrow. Told him the A/C fan wasn't coming on and he was clueless, didn't even know the car had another fan. I had to show him where it was, that's pretty scary. Told them to go ahead and flush the radiator and change the T-stat while they had it. Glad the fan clutch was under warranty! I'm glad they're replacing it because it sounds horrible, makes a loud roaring noise when you accelerate.
RS250 Chester
Aug 7, 2003 08:43 PM
RS250 Chester
Jul 14, 2003 09:55 AM
nismo240sxse
Apr 30, 2003 11:59 AM
DCTperformance
Feb 8, 2003 12:38 PM
sil-8-ty
Sep 14, 2002 06:44 AM
