Overheating...help
My 90 is overheating. Before it would overheat only in hot weather and when the A/C is on. But only in bumper to bumper traffic.
I changed the Radiator and thermostat. But it still overheated when the A/C is on and in bumper to bumper traffic. Today, it overheated without the A/C on, in bumper to bumper traffic.
What's going on here. Is the water pump next. Do I have a head gasket problem. There's now a small leak around the belt area, on the driver side. It's very small amount of coolant, but it's leaking periodically. It's not coming from the thermostat...any ideas, please help.
do you have electric fans or anything, or a fan connected to the water pump? My fans stopped working and I overheated fast as hell. I don't remember if you said you flushed your radiator or not, but you can try doin that. anyways good luck with your problem.
It also sounds like you've got a bad head gasket, youmight also want to check your coolant return lines. good luck!
