How to take off the corner lens???
i can't figure out how to take off the corner lens by the headlight ( zenki s14 ) to replace the bulb. The chilton doesn't tell you how to do it, and i don't want to go prying it off and break something. Someone please help me out on this.......
and before anyone says SEARCH.... i already did and it didnt help me at all....
thanks guys
thanks guys
wow seriously?
OK nm - remove screw (only 1 screw, and it's obvious where it is), place flathead between headlight and corner light, pry outward and it'll pop then come off. If it doesn't come off on the first try, it probably has never been removed since it was assembled by Nissan back way when. Either way don't be afraid to pry, it won't break that easily.
I think we're done here.
thanks guys..... at least your info was perfect..... however i figured this out when i went to schucks to get the bulb..... thank god i didnt break something prying that thing off..... P.S.- I did use a screwdriver to pop it off..... and it worked fine
edit: go ahead and close the thread
flipspeed
Dec 18, 2004 11:24 AM
