cross drilling stock rotors?
anybody ever do this or see it done. I think I am gonna try it. just cause I can and I have machines and rotors layin around the shop. if they work good I will do it for whoever wants it done.
Xdrilling is good but only on bigger rotors. Stock blanks v stock xdrilled = blanks will win. The blanks allow more surface area for the brakes to grab. xdrilled helps with cooling of the rotors but decreases the surface area. so if you run larger xdrilled rotors then the amount of surface area ould equal out. personally I think it really is personal perference. I have xdrilled all the way around because i like em but haven't noticed but difference from stock blanks
i have blanks. xdrill/slot is proned to cracking under heavy use.
xdrill is outdated tech. they first did this when brake pads use to give off gas and had them xdrilled/slot to vent the rotor, but considering todays tech, pads dont give off gas anymore so xdrill/slot is no longer needed. mainly used for "bling bling" factor
if your looking for good rotors... go with vented. its got the cooling of the cross drilled/slotted but they can be rottated like the stock ones. Unline the the xdrilled and slotted (cause you cant turn those)
As silvia driver said drilling and sloting are not for cooling but for venting gas that is generated by organic pads. Vented is the best for non organic. i run a emi organic compund so need the vslotted rottors.
who makes a good vented disc for the rear? without doing a big brake upgrade, cause the whole point of what I was gonna do was that it is an alternative to spending alot of money on a brake upgrade when you dont really need that much, but just want something a little better.
jdmsoarer
Nov 23, 2004 05:24 PM
flstseminolejd
Jun 16, 2003 02:52 PM
