How do you install coilovers??
Old Mar 7, 2004 | 03:03 PM
ryan15's Avatar
How do you install coilovers?? what is required when cutting ir grinding.
Ryan
Old Mar 8, 2004 | 07:08 PM
JeromeS13's Avatar
Cutting or grinding????? WTF kind of coilovers are you installing???
Old Mar 9, 2004 | 10:40 AM
I think Ground Control requires you to cut the lower stock spring seat on some cars, which in my opinion makes it more "Mickey Mouse" than "Properly Engineered".
There should be no cutting or grinding if you move up to a full coilover suspension such as Tein or JIC or Zeal.
If you go Ground Control, there might be cutting (again, I don't know if it's true because I've never had GC's on a 240SX myself) but nevertheless it's still more of an "addon" then a real coilover system.
If you go Ebay or NOPI or R1 or any other sub-$150 "performance coilover system" then cut your head off and grind it.
Way2StockRPS13
Aug 7, 2009 10:44 AM
Flip_240Sex
Mar 1, 2006 05:55 AM
war
Nov 22, 2003 01:20 PM
vale619
May 29, 2003 06:11 PM
