problem with the sr
problem with the sr
i got an sr20det redtop, in my 90' 240. and i am having problems with it. it seems to spool perfect and blow off perfect, so i dont think that it is the turbo, but when i get on it there is no power and it sounds really bad. and today i replaced the washer at the bov thinking i had a leak there and it didnt work. but the weird thing is it idles really bad and wants to cut off. but when the car was runnin i took off the connection to the maf sensor and it idled almost perfect. how can i check to see if the maf isjavascript:smilie('
mad bad?? need a lot of help.
john
')mad bad?? need a lot of help.
john
If you upgraded anything on the motor than the maf could be starving the motor of fuel. If you didn't upgrade your maf before, now is a great time to do so. I've also moved my z32 maf to right before the intake manifold so the air/fuel mixture is correct entering the motor. The bov and intercooler could alter the airflow and change the amount of air entering the combustion chamber. A little bit of change could cause the rough idle you were speaking of. Upgrade the maf and update us with what happens
uvamosk
Aug 12, 2005 07:31 PM
