VLSD install question
Old Sep 9, 2004 | 01:27 PM
KuhnDawg's Avatar
I own a 1996 240SX SE without a limited slip, so i bought a VLSD, i was curious just how many more parts i needed to install the VLSD into my car.
Old Sep 9, 2004 | 01:31 PM
From what car is it?
Old Sep 9, 2004 | 01:35 PM
KuhnDawg's Avatar
The VLSD is from a 240sx, unsure of the year though
Old Sep 9, 2004 | 06:14 PM
It should bolt right up then IIRC
Old Sep 10, 2004 | 07:01 AM
KuhnDawg's Avatar
I only have the differential, so figure ill need new bearings and a new gasket, and i assume i can buy that stuff from autozone, are my assumptions correct?
Old Sep 10, 2004 | 09:04 AM
Driftmonster's Avatar
oil seals, rear gasket, races and bearings... you can get away with using the old races and maybe the bearings depending on the mileage but the oil seals are about $4 for a pair at autozone. Make sure you get a good quality non-synthetic gear oil for the diff also. 80w90 GL-5.
Old Sep 20, 2004 | 09:03 AM
1995 240sx's Avatar
were did you get the VLSD from?
Old Oct 20, 2004 | 04:27 AM
zeroGripS13's Avatar
i herd u need new halfshafts... is this true,...
Old Oct 20, 2004 | 10:23 AM
only if you get the JDM or Z32 diff IIRC
Old Nov 14, 2004 | 04:44 AM
iroc07's Avatar
dont you need axles if you use a J30 LSD also?
onesloweg5
Feb 22, 2007 07:22 PM
Flip_240Sex
Mar 1, 2006 05:55 AM
cmhadley
Jan 22, 2006 10:52 AM
Djrockz415
Sep 19, 2004 12:08 PM
chwwilliam
Feb 15, 2004 02:37 PM
