SR problem.......
Old Feb 26, 2004 | 07:33 PM
smokie700's Avatar
sounds like fuel isn't makin it to the injectors maybe fuel filter or pump
Old Feb 27, 2004 | 01:12 PM
s240r's Avatar
i can tell you right now that it is your coil packs, i had the same thing with my sr20det, i replaced 2 of the coilpacks, and problem was solved.
Old Feb 29, 2004 | 05:29 AM
Zdrifter's Avatar
it would be a good idea to unbolt each coil pack and check them for spark by lying it on top of the valve cover with a spare spark plug in the end, grounded to something. Then crank the car and watch the electrode for the presence and quality of spark. You'll locate the bad coil pack very quickly. Also, in a situation like yours where full throttle doesn't produce the power that part throttle does, it can be a bad tps.
Old Feb 29, 2004 | 09:34 AM
chwwilliam's Avatar
what is tps?
Old Feb 29, 2004 | 10:09 AM
tommyboy's Avatar
it is your throttle-postion sensor. it is located right on the throttle body.
Old Mar 1, 2004 | 02:01 PM
s240r's Avatar
justc check the resistance on the coils, its alot easier than doing that spark test. Just get 2 new coils, trust me it will be fixed.
vortxxe
Apr 29, 2006 05:22 AM
uvamosk
Aug 12, 2005 07:31 PM
altima/240sx
Sep 28, 2002 08:04 AM
kackarot
Feb 11, 2002 07:31 PM
240sxer
Feb 11, 2002 02:55 PM
