difficulty starting
Old Mar 25, 2007 | 10:04 PM
acfalconhawk's Avatar
difficulty starting
occasionally my car won't start. the starter cranks but the engine won't catch. i have to push start it. It doesn't happen all the time. usually it happens if i cut the car off without turning the a/c off or the stereo off. even if i turn ignition on to turn those things off, if i leave it off for a few hours, it won't ignite.
I don't think its the starter because most of the time it starts up instantly. It only happens when i need to go home. Could it be my battery not holding enough charge by the time i start it back up? I tried searching but none of the other threads matched my problem.
Old Mar 25, 2007 | 10:07 PM
could be the battery or the alt not charging the battery. most major parts stores will check both for free.
Old Mar 26, 2007 | 10:53 PM
s13gold's Avatar
check for corrosion under the terminals...take them off and check the wires.
Old Mar 27, 2007 | 06:34 PM
the battery was tested and its great. no corrosion on terminals. Ignition side is good. That just leaves fuel.
so I took it to our local shop to be checked. hopefully its something simple.
Old Mar 27, 2007 | 06:37 PM
a car need At lease 8-9volts or so from the battery to crank. sounds like you have something draining power somewhere bro. do you have any after market electronics??
Old Mar 27, 2007 | 06:40 PM
not just that but a good amount of amps too. i had a batt. test good but when i cranked the car nothing.
Old Mar 27, 2007 | 06:50 PM
yeaup,,,,,,,,,
Old Mar 28, 2007 | 10:20 AM
It usually does it if i turn the car off without turning off the A/C first. even if i turn the ignition back on and turn it off, if i let it sit for a few hours, it won't start.
shak180
May 2, 2007 12:17 AM
cwc2k1
Jun 14, 2003 08:51 AM
Ozzmosis
May 5, 2003 07:56 PM
Griffin
Feb 12, 2003 12:56 PM
rbboyl
Jan 20, 2003 03:11 PM
