effing tail lights
When in the **** would you do that, thats just asking for attention. That dude musta done that **** for TV.
I dont know if it was for the show or not, but I swear it was on there. The thing was it would be impossible to read from more than 2 feet away. Sorry i cant help you cronux. Can't the switch on the brake pedal go bad?
i just remembered that their maybe a button switch under the brake pedal. when u step on the brakes it causes it to give voltage. in turn, your stop light turns on. i had a similar problem with my previous car, having the stop light on at all times. maybe a possibility that it can cause it to have it off. check and find the plug on that button and check that voltage on that too. it should give you a reading when you press the pedal. aside from that i dunno. hope this helps
its not my brake lights that dont work. the bulb for the brake lights is a dual filament bulb. it has one filament for the brake lights, and one for the "tail lights" which i also call rear running lights, because when your headlights are on, those are supposed to be on. but the brake lights work fine.
Lol cronux thank you for teaching us all how light bulbs have dual filaments. jp man, but you should check into your headlight wiring then. Do your side marker lights turn on? Or do S14s even have that?
Yeah S14s do have the side marker lights. You are referring to the ones on the front end right? There are sidemarker lights that come on with the headlights that are located just infront of the wheels.
Yes, well on my S13 I had problems with the alarm. When I locked it the lights stopped flashing. Turns out I had a burnt out side marker. I replaced it and the lights started flashing again. It's worth looking at if you've tried everything else.
im not at my car right now, at a friends house, livin it up (hahaha) and my car is at home..but thinking about it, i dont think my sidemarker lights work. and there is a burnt bulb in the rear i need to replace as well. soo we'll see if that does any good.
check the bulbs, obviously.
does your tag light work? the tag light is tapped right off the power wire for the tailights. if it doesnt work, its a voltage issue. if it does work, its a mechanical issue (bulbs, contacts, corrosion, tailight ground, etc)
