Smelling and Squeaking
Ok, I just got a new clutch, flywheel, and front end in my 91 240 le. After I drive it, it has a weird smell coming from underneath it. Is it just because of the new clutch/flywheel or is something burning? Also, through first, second and reverse gear the car squeaks loudly. After 2nd it doesn't anymore. Any ideas on what that is and is it bad? Thanks.
i installed brakes once and something got between one of the pads and rotors. Didn't really squeal, but I was driving and I smelled something horrible when I stopped at a light. I was like I wonder what that is. then someone pulled up next to me and told me taht my wheel was smoking, LOL.
I ended up taking it back apart, spraying it with some brakleen and putting it back together. problem solved.
i for got about that, If you put new rotors on when you did your front brakes and you didn't spray them down really well with brake cleaner, oils from the new rotor's will burn and smell really bad. make sure and spay throught the middle of the rotor's too to get every bit of oil and grease out.
Originally posted by QR25DE
what is "WARPED"?
what is "WARPED"?
under normal driving you usually don't have to worry about warping rotors. Warping can also occur in the rain tho, when the cold water hits the hot brakes.... but that doesn't happen too often. I drive like a jack@$$ sometimes and I've never warped any rotors....
...they do kinda sqeal when i brake...I'll hafta check on that...why only low gears tho? it like stops in 3rd +?
