How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Rear Traction Control Link Install
Old 01-05-2007, 05:31 PM
positron's Avatar
I swapped out my stock rear traction control links with some aftermarket links today...here's the pics.
Tools needed:
Jack
Jackstands
Socket wrench
18mm sockets
3/4 wrench
Breaker bar
Torque wrench
Crescent wrench
First, jack the car up and place the jackstands underneath.
Stock traction control link...it ends today!
You'll need a breaker bar to break each end of the control link. Then use a 18mm socket and a 3/4 wrench to remove the traction link bolts.
Next, I used a small hammer to tap out the bolts from the frame and spindle.
Ran into a problem here, one of the traction link bolts was facing the rear upper control arm so when I tried to remove the bolt it was blocked. I used the same 18mm socket and the 3/4 wrench to remove the outer RUCA(rear upper control arm) bolt so I could take out the traction link bolt.
Everything's pulled and ready for the new links!
Use a crescent wrench to spec the link to the same size as the stock link. I went with the Megan Racing Traction Control Link.
Now you can place the links and tap the bolts back in.
If you had to remove the RUCA then you need to put it back the way it was as well.
Don't forget to tighten the adjusting bolts with a crescent wrench. Torque the inner bolt to 51-65ft. lbs. and the outer bolt to 57-72ft. lbs. then hit up the alignment shop.
positron is offline
Old 01-12-2007, 12:20 PM
JDMxDrift's Avatar
nice, i just did my tension rods and about ready to do the whole rear end too. you didn't do RUCA's?
JDMxDrift is offline
Old 01-21-2007, 03:54 AM
positron's Avatar
That's next on my list.
positron is offline
Old 01-21-2007, 09:52 AM
Nice write up
Bryan is offline
positron
04-12-2007 03:52 PM
positron
13
03-21-2007 09:19 AM
positron
02-14-2007 05:45 PM
deloesian
01-13-2004 11:24 AM
playboycougar
11-18-2003 10:03 AM
Quick Reply: Rear Traction Control Link Install
