Removing the clutch fan for good
OK, so lets say I remove the clutch fan and install an electric fan or two. What should I wire them to so that they remain on all the time. I am hearing headlight relay, switch on the inside, etc. what do you think would be the best and easiest to wire it to?
i think i need to take a picture of the bigger secondary fan on a s14 becuase some of you don't know what i talk about lol...
its not a small fan and its not on the A/C condensor
there's a writeup in NICO about wiring the fan to a temp sensor and also to a switch, or both if you want. i know this site blocks any links made to NICO, so i'm not gonna bother pasting it here, but if you go to the site, search for "electric fan wiring" you'll find the write-up with pics and a schematic of the wiring.
personally, i'd like to have the fan attached to a temp sensor because at highway speeds, you don't need the fan, and you don't have any parasitic HP loss. a switch is OK too, but i think it's better to have it automatic than to have to remember to turn the switch on and off.
i guess to each his own.
